Jul 4, 2013 #1 N nightowls_gm Member Joined Oct 14, 2006 Messages 37 My boost gauge is reading 20 vacuum at idle, but only shows 5psi in boost.is my wesgate bad? Do I have the boost gauge hooked up in the wrong spot? Posted from the TurboBuick.Com mobile app Attachments 1372966616526.jpg 53.8 KB · Views: 117
Jul 4, 2013 #2 T turbobooster Active Member Joined Nov 12, 2002 Messages 1,549 It's in the right place that's where mine is hooked up might b a bad wastegate or some kind of vacuum leak check all hoses around turbo area Posted from the TurboBuick.Com mobile app
Jul 4, 2013 #3 N nightowls_gm Member Joined Oct 14, 2006 Messages 37 Ok thanks, I have an extra wesgate I swap it tomorrow Sent from my SGH-T999 using TurboBuick Mobile mobile app
Jul 5, 2013 #4 N nightowls_gm Member Joined Oct 14, 2006 Messages 37 Changed the wastegate, same thing. Didn't find any vacuum leaks I used propane to find them. Posted from the TurboBuick.Com mobile app
Jul 5, 2013 #5 B BRAD_PADGETT Well-Known Member Joined Jan 22, 2004 Messages 3,566 A plugged CAT can cause this problem as well. Brad
Jul 5, 2013 #6 N nightowls_gm Member Joined Oct 14, 2006 Messages 37 New cat, just passed smog. I'm wondering if maybe the Wastegate sol? Sent from my SGH-T999 using TurboBuick Mobile mobile app
Jul 5, 2013 #7 T turbojoe1 Active Member Joined Feb 9, 2013 Messages 942 You clearly need to relocate my friend, you taped into the water passage and leaking coolant as a result
Jul 5, 2013 #8 T turbojoe1 Active Member Joined Feb 9, 2013 Messages 942 Take that back, post another pic of the boost ref lines. Sorry
