Boost Spike
87WE4BOOSTED
I NEED MORE BOOST!!
Last night on my way home, I was merging on the freeway and rolled into the throttle, looked over at the boost gauge right about the time it usually hits 15 lbs and I noticed it went past 15 lbs and nearly hit 20 lbs. :eek: Scan master read about 12 * knock. :eek: I did not get back on it again. Since it was late I did not get a chance to pop the hood. What could have caused this?
I am using the stock DP turbo with an stock adjustable wastegate.
Being a stock setup, this is what I would suspect...
Sounds like you might have a hose that has popped off on either the wastegate solenoid, or the wastegate actuator.
Check these hoses.
Turbo and wastegate hoses.
Wastegate solenoid hose. Solenoid bolted to front of passengers side valve cover.
If the integrity of one of these hoses fail, you could have boost spikes or run away boost. This will lead to head gasket failure. Also, check for signs of dry rotting on all of your vacume hoses.
Hope this helps.
Patrick
i had te same problem today i looked over and i was at about 19psi after i got i off the gas it started backfireing really bad and missing after a few minutes it was ok so i gave a wot again and it did it again back fireing and seemed lie it was going to die i was trying to pull over to the side of the road then it started running fine so i just crused it home i hope this is my problem. before today i couldnt get it past 15 psi and it didnt matter what i did. I noticed lately if the fuel gets kind of low it started to hesitate but when i gas it up past a 1/4 tank it was fine and i was back at 15 psi no knock. what could this be. today i did fill it all the way up and that when it started happening.
leehatten,
One things for sure, with todays craptastic gas, our cars can't handle 19 psi without aluminum heads and or a front mount intercooler. If your chip has 19-20* timing under WOT, you could see detonation at 19 psi especially on a street chip. And of course, the colder temps will raise your boost level. If it was at 15 psi during the summer, it could very possibly go up to 19psi in colder weather, especially if you're utilizing the stock 21 year old wastegate solenoid and wastegate actuator. 15-16 psi has pretty much been the safe level for years.
Your stalling out and or fluttering issue when below 1/4 tank could very possibly be an innacurate fuel level gauge. It's very common that the gauges can be very innacurate on the factory gauges, I've had one be off by as much as 1/4 tank. If I tried to run that car down to 1/4 tank, it would stall, spit sputter and even die on me. It happens with age.
Now days, unless the car has a new sending unit and an extra ground strap from tank to frame, I try to fill up when the needle gets between 1/2 and 1/4 tank.
The only real way to know for sure if your gauge is off, would be to drain your tank completely dry, and fill it up with a preset amount. Then noting where your needle is for that preset amount. Very time consuming if you ask me. The other method would be to install a temporary fuel pressure gauge that you can see while driving. Let the tank get down to 1/4 tank. Make a run and watch the fuel pressure gauge. If your fuel pressure starts wildly fluctuating or you get the dreaded bouncing needle, this is a sign that your pump is sucking air from either fuel slosh or low fuel level.
I never recommend racing/WOT runs on a 1/4 tank of gas with factory sending unit/tank. It's a recipe for destruction.
Hope this helps a little.
Patrick
may be a hole in wastgate line or diafram in the waste gate
As soon as I got home yesterday, I checked for all vaccum lines on or near the turbo. all seem to be on. :confused: I will look at replacing the wastgate line and the waste gate. Should I go ahead and get the waste gate solenoid as well?
