Went to the track last night after opening up the valve lash per Billy Anderson's suggestion to try and solve a boost drop problem. Still doing it. Boost starts dropping at about 6500 rpm and will lose almost 4 pounds by 7300.
HKS GT wastegate--adjusted tight as possible with stock(?) spring
4 bolt 88 turbo
274 Stage II with Stage II heads
70mm throttle body on a Hemco intake mated to a stage II intake
750 pounds of pressure over the nose, 280 closed
Using an innovative boost controller
MSD DIS--have not tried to bypass it yet
CAS front mount
3.5 downpipe
Car ran best being short shifted at 6500 rpm.
Went consistant 6.02 @ 117 1/8 mile last night.
If I tried to stretch it out to 7300 times dropped to 6.3 @ 112
Boost controller had no problem holding a 12 or 14 pound launch boost setting, and boost would peak wherever I set it at (25-27 pounds). I guess next step is to use an old school bleeder for boost control and/or bypass MSD box. 70mm throttle body shouldn't be a restriction at this level? Suggestions?
Greg Kring
Arlington, Texas
4 bolt 88 turbo
CAS front mount
3.5 downpipe
Greg Kring
Arlington, Texas
