Boost Trouble, PLEASE HELP!!
nash421
I recently added an Ais alky kit and cannot get my turbo to give me more than 18lbs. I have an adjustustable actuator which is maxed out and a Haulman bc... Out of ideas. it holds steady boost so I dont think there is any vacuum leaks. Ideally would like to be around 23psi. Any info is appreciated
Need a lil more info. Setup? What was your boost before? Scanmaster/powerlogger readings? You may get more help on general tech.
You really have to pull on the actuator. Pull on that sucker. Aim for 1/8" from the spindle to actuator rod.
Joe
The op posted this in a few places and found he had the light spring installed.
