Boost won't go higher
Thanks eveyone for your advice as to what I needed to do.
This little turbo spools instantly with the current combination, actually too fast for the street. It doesn't run that bad down the strip either.
I was trying to get the boost up in the 25/26 # range, I think there might have been a 10.5? second pass. After turning up the wastegate rod a couple more rounds, on the last pass I had an exhaust manifold gasket let go after leaving the line. Ended the day listening to that get worse while driving home.
