SignUp Now!what is the weight of your car?the pte.63 has been much faster than 124mph so i don't think your restriction is there.if your weight is high,your probably at the limits of the turbo or keep shortening that rod.
update, made it to the track yesterday. Tightened the wastegate rod 2 more turns and shimmed the rjc valve with a washer, boost was at 23#. The car ran 10.73 @ 124.89.
Update, made it to the track yesterday. Tightened the wastegate rod 2 more turns and shimmed the RJC valve with a washer, boost was at 23#. The car ran 10.73 @ 124.89.
Man bad V6, you got that 6152 flying, definitely the fastest I've heard of.
I would absolutely love to see what a Billet 6265 ACBB with a .85 A/R housing would do on your combo. My guess would be some 10.40's at similar boost levels, once you get the spoolup worked out with a new PTC converter.
It is so true, bigger is not always better.
Patrick
