TURBOTIMMER
- Jan 5, 2002
Not that it would have helped your situation Nick, but I really wish cometic made 8 bolt head gaskets. You lose a good bit of sealing surface with the extra 6 holes.
SignUp Now!Finally I had a chance for some track testing today, and wanted to baseline the car/engine/turbo even though I was satisified with limited street performance, but I wanted more data.
The first track pass was a "drive" down the track was a 12.6 run with a plug wire not connected, just laying on the plug.
Boost was set at 15 psi for the second pass, and it ran fairly well with a 11.07 @ 122 MPH, which would have been factored into the ten's, as the track is at 3000' altitude
Back in the pit, it seemed very obvious a head gasket finally gave up during that run?
11.0 @ 3,000' on 15 psi of boost with a hurt gasket. That's pretty respectable for a 57mm turbo that spools so quick and has great street manners due to it's lightweight Titanium Aluminide turbine wheel with ceramic ball bearings.
I look forward to hearing about what a clean pass at higher boost levels brings.
Best of luck and thanks for the update Nick.
How'd you hurt the headgasket(s) ?
I wish I could give an accurate answer, but an opinion is the best I can do?
Over the summer I had various electrical issues and one of them was the fans working intermittent and did see 210-220 degrees water temp after a few test passes. With 100+ deg temps this certainly is certainly a major factor.
It was consuming about a quart of water after each test session, but never showing up in the oil?
After the first run at the track yesterday, the engine was hot again and the fans were not working. We then bypassed the relays for the next run.
I plan to eliminate the stock fan wiring/relays, and use a Casper's fan harness/relays with power and ground direct to the battery.
It’s a 57mm?
During the time the engine consumed water while cursing (no load)on the street / highway did the engine experience random knock?
Has the 3-bolt housing been developed/made available yet?
Is there a model that is best suited for mounting in the traditional Buick style?...........
Nick, is this a stock stroke 109 and what heads?
