SCOOBY DOO
BASED CANADIAN PATRIOT!!
- Feb 18, 2007
Thanks Nick. Was hoping this was a stock stroke 109 with a pair of Champion irons. Still interested in what this turbo will do with what it's bolted too.
SignUp Now!Production 4.1 block with 3.625" stroke, well ported SE heads, and a solid roller cam which shifts at 7000 RPM using a 200-R4 trans, 3600 NLU 10" converter!
This is our typical high 9 sec. street build.![]()
No kidding, I'd be interested to know.That’s a lot of RPM, what cam?
7000rpm high 9 sec street build? Way too much cam, too much overlap. That is running 9s the hard way.
Well, I run a 0 overlap cam, 6200 rpm shifts, and with a 4.1 runs 8.6s on 25psi with a 3 bolt 72mm turbo. I have seen many bigger and better cams run slower. I would guess you need all that rpm to couple that converter.
Mike, I do not want to offend you, but this thread is about new technology using a 21st, century turbo. and how well it performs.
I posted details about supporting items on this specific build to add tech to possibly help others that want to go this route.
The camshaft grind discussion has already taken it slightly off-track with the cam specs discussion, as the original objective was to prove or dis-prove the use of the BW turbo for primarily street use, not what is needed or wanted to build an 8 sec. GN race car.
Opinions are fine when stated as such, but I want to stick to what the supporting items work well for the BW turbo. Mike, you are a gentleman, and certainly hope you take no offense personally, thanks.
Any word on when might get a 3 bolt housing?
For the EFR turbos or for Borg Warner turbos in general?
I do not see a 3-bolt EFR turbo in the future with
Ask for Reed if you contact WORK Turbochargers. He will point you in the right direction.
I do not see a 3-bolt EFR turbo in the future with the same responsiveness as the 4-bolt twin scroll design, because of various factors.
