BOV users?
yes you do...
mount the niple before the maf.
it still makes the noise but there is no stumble or surge.
so the rerouted air goes before the maf sensor and not after in the inlet pipe?
wouldn't it throw the maf/ecm reading off due to it already reading the air that is being redirected?
would the rerouted air niple go after the maf sensor in the inlet pipe?
i'm confused.
i havent done much experimenting with this as the car is put away for the winter but how it is now, it is alot beter then it was.. i did try having it routed to the atmosphre but it stumbles worse than with it rerouted.. i was mostly doing this to get rid of the woop noise and it made the stumble go away.
I run a Tial 50mm rite in the up pipe, no mass air, talk about the 3 stooges sound, a 70 GTQ sounds like a bunch of bricks rattling around in a can.
With this valve, thats all gone !!!! Just have to play with the springs, still waiting for Tial to send me the spring I originally ordered. :frown: Its only been 6 weeks!!!!!
WEAK customer support!!!!!!! Valve stays slightly open at idle, but blows off every little surge.
