Jan 24, 2015 #1 H Hot Air E85 and S.E./Carolinas Moderator Staff member Joined Nov 11, 2002 Messages 3,102 my car is mostly street driven with some Autocross in the future. What spring should I run?
Jan 24, 2015 #2 Jerryl Tall Unvaccinated Chinese Guy Joined Dec 14, 2004 Messages 9,644 Does that not depend on the size of the BOV?
Jan 24, 2015 #3 2 20psiofevil Active Member Joined Feb 10, 2013 Messages 628 I believe manifold vacum dictates spring pressure for the bov.
Jan 24, 2015 #4 H Hot Air E85 and S.E./Carolinas Moderator Staff member Joined Nov 11, 2002 Messages 3,102 I agree but at what point do I want valve to open?
Jan 24, 2015 #5 2 20psiofevil Active Member Joined Feb 10, 2013 Messages 628 It needs to stay shut until you shut the throttle after boosting. What bov are you running?
Jan 24, 2015 #6 H Hot Air E85 and S.E./Carolinas Moderator Staff member Joined Nov 11, 2002 Messages 3,102 I have Godzilla (not installed) but looking at Tial Q 50mm on EBay. Come with 6 to 11 psi springs.
Jan 24, 2015 #7 H Hot Air E85 and S.E./Carolinas Moderator Staff member Joined Nov 11, 2002 Messages 3,102 According to Tial's web site, spring selection is only dependent on engine vacuum at idle!!!! Conrad
Jan 24, 2015 #8 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 Pressure test the intake tract and be sure the valve isn't opening under positive power. I've seen a problem with a t-netics BOV that opened under boost and crippled the car it was on Sent from my iPhone using Tapatalk
Jan 24, 2015 #9 2 20psiofevil Active Member Joined Feb 10, 2013 Messages 628 I use an adjustable 50mm. Bench tested to 30psi no leaking. Attachments d3ad_12.jpg 37.1 KB · Views: 111
Jan 25, 2015 #10 G Gnx6 Member Joined Jun 22, 2003 Messages 554 Either the plain spring or the yellow. With the white spring the valve will hunt open and closed at idle and run like poop. Ask me how I know...
