Mar 7, 2010 #1 F fmster Member Joined Dec 18, 2008 Messages 287 Doe's any body have a blow off valve on a hot air? HOW DO YOU HAVE IT HOOKED UP AND WHERE? If you have pics it's a plus.
Mar 7, 2010 #2 B Boostnitup Member Joined Feb 20, 2002 Messages 701 Test question? If it is "Hot-Air" where the turbo is blowing directly into the intake... how would one have a BOV? So... you are considering an intercooled conversion?
Mar 7, 2010 #3 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 You'd have to drill a hole in the intake to use one, which I think would be counter productive.
Mar 8, 2010 #4 D dr_frankenstein Mad Scientist Joined Mar 17, 2008 Messages 5,126 in a draw thru system the is never a build up of pressure in the intake. unless you catch a nasty back fire. A.j.
Mar 8, 2010 #5 T tb3 elbows & a$$holes Joined Mar 31, 2006 Messages 2,716 did you maybe mean to say "external wastegate"?
