A/c bracket
turbobooster
Does someone sell a bracket that replaces this a/c alternator bracket? Since I’ve completely removed a/c system this chunk of metal isn’t necessary IMO , wondering if there’s one for hotairs that just supports alternator ?
You may have to fabricate a bracket for just the alternator or cut up that pretty shiny one if your goal is to clean up that area.
Check out this bracket: Non-AC/AC Delete Alternator Bracket
I think it's for the 86/87 - but will it adapt to the 84/85 ???
Is this one any different than what you have?
I've got one similar to that. It required using different pullies and sourcing the arm to adjust it.
Yours is slightly different. Mine is from an early Jeep engine with a single groove pullies. Also had to use the early style short water pump.
Thanks to everyone ! , Hotairwh1 I think that post #5 on that other thread is what I’m looking for , now just have to hunt down that part, they used it on a before 84 /85 GN hopefully it works on 84/85 without having to change much but the bracket …. Thanks again
After taking a look at the engine bay and visualizing that early model bracket it looks like it will bring down the alternator a couple of inches (4-5) , you think its going to require a different water pump? For sure a shorter belt
My car is in storage so I can't see the AC bracket bolt to engine block locations. Question is could the "early model Alternator bracket" be pivoted up to accept the alternator near its existing location?
Several for sale on eBay: 1964-1976 Buick Alternator Mounting Bracket. Aluminum for Non-AC Cars
