Box o Stuff
LikeMySix
Got out of the Buick scene 2 years ago, just ran across a box of buick stuff.Most is new and still in the original boxes. I have no plans on selling each item seperate so it goes all together in a package deal. I figured $200 plus shipping is fair. The retail cost for all this stuff is over $500
Items are:
-HRparts bushing tool #0599 with instructions
-HRparts frame sets 2of #250 and 1of #251 all brand new still
-ARP 123-4203 head stud kit.This was installed on a engine that had bottom end thrust failure during break in from excessive transmission pressure.
-Duttwieler cork pan gasket unused new.
-Felpro front cover gasket set new in box.
-New rear main seal kit for factory block.
-GMP Conley Tweaked diecast Mint still in box and signed by conley on its roof.
-ATR copper header gaskets
-Felpro 1400 graphite header gaskets
-2 factory S hoses for water pump connection to intake.
-assortment of silicon hoses 3" and a 3" reduced to the factory throttle body.
-1 total seal ring compressor piston install tool bore size 3.780-3.885"
-1 factory water pump pulley
-1 new trans mount for stock trans
-1 proform shift light with instructions
-1 moroso battery shut off switch still in the factory package
-1 braided steel oil return for factory turbo location to stock block
-1 factory new grey pressure switch for powermaster
-misc factory parts(fuel filter,fandelay relay,washer pump,IAC,shifter handle,trans lock up switch,water pump pulley)
Thanks for looking
Frank
