Brackets and acessories 84 to 87
I need everything except long block, injectors, cam sensor, and ignition.
I have a stock "up pipe", some hoses, the oil cooler lines with adapter, turbo oil return line, a turbo cover bracket (which bolts to the front of the block), egr valve with bracket and plastic cover, stock rockers ans shaft assembly, stock intercooler..."PM" me with more delailed info about what you need...
Claude. :smile:
