The pressure switch does exactly what the name implies. Is senses pressure created by the E-H motor and once the accumulator reaches a specific pressure, it shut the E-H motor off. As you pump the brakes, brae fluid pressure is bled off the accumulator and the pressure switch signal the E-H motor to turn on once a specific pressure reading is met.
