Got my car back from the shop after having yet another engine put in and the brake light is on intermittently, mechanic takes a look and says the right rear wheel cylinder is leaking and needs to be replaced. So I grab the part but before i can replace it i loose almost all the breaks, upon inspection the master cylinder is leaking fluid on the rear side, pressure switch?, and the plastic diaphragm is not connected to the cover. My question is does the master cylinder need replacing, i know there have been many issues with the stock ones, or is this just a symptom of the fluid leaking at the wheel cylinder. If the master cylinder does need replacing, what is the best option? Vacuum conversion or rebuilt stock part?
