my resivior (spelling?)is leaking where it connects to the master cylinder. is there a fix for the problem or does the whole thing need to be replaced?
Yes, it's sucking in air every time you let off the brake pedal.
The air is making your pedal soft, and over time will ruin your pads and shoes.
Fix the leak, bleed your brakes and you should be good to go.
