my85grandnation
85 Triple Threat
- Mar 12, 2004
I just got my 85 GN back from the brake place and it was insane how much it cost. The previous owner or at least someone before me had put an oil additive of some type in the master cylinder. As we all know oil in your brake lines is not good, it deteriorates the rubber lines as well as the seals in the pistons and everything else. Basically I had to get an all new system from the master cylinder, all the way to the front calipers, and rear pistons since all the old stuff got gummed up by the oil product. The only thing that wasnt replaced was the rear lines and the hydroboost unit. I also had to have my rotors and drums replaced because when the old calipers and pistons failed they did so in the out position causing them to ride on the drums and calipers grinding them down. The wierd thing is when this happened the brakes didnt squeel or make any noise and the car didnt seem like it was dragging anything so I didnt relize it was happening. The grand total for all this was $1200. My main point is, is it worth it to keep my hydroboost system or do you think I should switch over to vacum brakes?
