Hello Everyone
Just finished replacing all of my brake lines. As I blew out a wheel cylinder 2 years ago and the car has sat since.
I followed a brake bleed procdure which I found on the site.
I used the c clamp to hold in the proportion valve that is under the drivers side floor.
I bleed everything multiple times until the fluid was clear, no air bubbles and no hissing. When I would put the brake pedal to the wall, the brake light would come on, once the bleeder was cracked, the pedal would go a bit closer to the firewall and the brake light would come on.
Completed the bleed procedure from passenger rear, driver rear, passenger front, driver front.
All is clear, but now anytime I put the pedal down in the car the brake light on the left side of the cluster comes on.
Any suggestions?
Thanks all
Any suggestions?
Thanks all
