Hydroboost conversion
The fuses blow, because when the 12v motor wears out, the brake fluid leaks into the windings of the motor, and shorts it out. That motor pump is THE no. 1 problem on this forum. New ones are difficult to find, and then the accumulator or switch takes a dump. it keeps going around. The Hydroboost will out stop any other system, and can out last the car. The 83-85 T-Types came WITH a Hydroboost, and no one ever complains about them. 27 years later! The NEW ones work even better. Bendix made the Hydroboost originally, and Bosch bought Bendix in 1995. Bosch has been producing them ever since, but only for the automakers, and a couple other outside distributors, such as Power Brake Servce.
