SignUp Now!The turn signals and hazards use the same circuit. If they are working the turn signal switch in the column is on the fritz.
RL
I had the same problem and it was the flat connector as stated in the last post. Easy fix if that is the problem. The white wire was broken.There's two things I think it could be. In the flat connector under the column, there's a white wire that corrodes going into the connecter.
Or, it could be a defective turn signal switch as noted above.
