Eagleguy, do yourself and your car a HUGH favor. You can get a remanned unit from Kirbans complete, and then change the fluid in the mc yearly, which is not a big deal, with lifetime warranty. Seems like mine was around $800, but that was 2008 so my memory is a little fuzzy.
For a whole lot less money you can put in vacuum brakes, which will not hold boost on the strip as well as the powermaster, but will not surprise you and kill you or the car. I like the brake "feel" of a PM that works correctly over vacuum, but I'm wary of my PM. ( I have multiple cars, but my daily has vacuum).
As another poster said, there is also the hydroboost option. Some folks think it's the better option as far as psi, but it only works if the engine is running. With vacuum, if you blow the engine, you have a few pumps to get the car stopped. With the PM, you have electrical assist to stop the car.
A friend of mine that was an engineer at Buick in the day said the reason they went with the PM was they knew the brakes were undersized and would need all the help they could get, along with seeing if the PM was a viable alternative to vacuum. That didn't last long
