Sometimes (not always) brake fluid in the switch connector is a sign of a bad switch. Replacing the switch is easy enough. Just depressurize the system by pressing the brake pedal (in key off position) until you get a hard pedal. It may take 5 or more pumps. Disconnect the plug on top the switch, unscrew the switch, then screw your new switch in and reconnect the plug. IIRC, you may have to reuse your o-rings...
The motor on the other hand is harder to come by as they don't make them anymore to my knowledge. Finding someone who salted one away is not easy and if you find one, will be expensive. You could always buy a used one but you'd be rolling the dice on how long it will continue to work, if it works at all.
You're at a point where you need to make a business decision. Continue to throw parts and money into your current Powermaster and hope for the best until it fails you again, buy a whole new PM setup for $600-$700? and hope it doesn't fail you, or heed the advice given to you at least 4 or 5 times in this thread and go vacuum (~$300) or hydroboost. Whatever you choose, please stop driving the car the way it is now. You and others around you may not be as fortunate as you have been next time.
