John Larkin
Sublime Master of Turbology
- May 25, 2001
Yesterday I took her around the block for the first time this year. Pedal was rather hard and car was tough to stop, hard pedal but plenty of vacuum (vac brake conversion on my car). Booster was holding vacuum when I pulled the check valve out. Tonight I cleaned both rotors, sanded the pads with some 60 grit sandpaper to get rid of the glaze and sanded the rotors with some 220 just to give them a little texture. Put some anti-sieze on the areas where the inner pad should slide. Cleaned up with brake klean and reassembled. Went back and forth in the driveway braking at either end as hard as I could. Then I went around the block again and they felt a little better. Could the pucks have been stuck from just sitting? I know these are the quick take up type calipers. Maybe they just need to be used. I probably need to readjust the rears to get the pedal more responsive. Any tips?
