I am guessing you broke yoursStupid GM plastic PS resevoirs!!!!!!!!!! Who the funk designed that garbage!!!!
SignUp Now!I am guessing you broke yoursStupid GM plastic PS resevoirs!!!!!!!!!! Who the funk designed that garbage!!!!
I am guessing you broke yours![]()
You are welcome to do it here. Lift will really help with those bushings.
Those are in the rear, but yes.Oh man that would be great. I think you mentioned you did GNX bushings? Would you recommend doing those for the front?
You will need this bushing kit
http://www.kirbanperformance.com/product/43851/REPRODUCTION BODY MOUNT BUSHINGS CUSHIONS (22) KIT #7305.html
Plus the Radiator core support bushing.
http://www.kirbanperformance.com/product/43850/RADIATOR CORE SUPPORT REPRODUCTION BUSHINGS CUSHIONS (2) KIT #7304.html
And the Bolts you mentioned.
I went with Polyurethane bushings from Prothane on Jegs. I like them alot.
http://www.jegs.com/webapp/wcs/stor...ctId=534584&storeId=10001&sType=&pgGrp=search
The ride isn't super harsh? I've heard real bad things about urethane bushings. I don't mind a rather rough ride just don't want squeaks and rattles.
I have all poly in the rear then a mix under the doors and all rubber off front. Why? Because I did not have a full kit and was bored on night. Cars been like that for 2 years. Also have tubular uppers with a custom alignment specs and the 2 piece aluminum lower control arm bushings. No squeaks and rattles here. Xavier you have been in my car a couple of times.
I am doing one here now with all poly bushings and rubber on the control arms and a factory delco shock. As well as poly on the rear control arms from HR.
If it is doing it it's only under certain circumstances. Because when I crawl under its not touching anything. Plus I can't find any wear marks close to it. I took the links out and am putting new moog ones in correctly today. Gonna contact bilstein about new bushings tmw.Could be, replace them and let us know. Since it happened after sway bar reattachement....did you ever think it is upside down and hitting the frame during those movements or off to one side.
