Originally posted by JoyOf6 As a follow-up to the extra water port situation, I plugged them yesterday: ran a reamer down each hole so a 1/2" pipe tap could easily engage, and ran the tap deep enough to sink pipe plugs.
In case anyone who doesn't know actually cares about this minutia, the surface diameter of each water port varied no less than 0.010" depending on where it is measured and not all the holes were identical in their max diameters (mine ranged from 0.631-0.643 max hole-to-hole).
Thanks to Cal and Bill for their responses here and to Todd and Brent for private counseling.
Were these extra ports in anticipation of a proposed change to a
reverse cooling system design at GM that never happened?
For the sake of someone who doesn't know any better, what holes need to be blocked??
I may not even need to, don't know, since I have something of a hybrid aluminum block.
Originally posted by TurboDave For the sake of someone who doesn't know any better, what holes need to be blocked??
Originally posted by Big Stu Sorry, can't help with the "holes" thing, but what do you mean that you have a hybrid block? Are you using an old stage 2 aluminum indy block?
Well, I wouldn't exactly call them an "indy" block. They are patterened after BMS blocks. They have a Buick 6 logo on them, but absolutely NO numbers of any kind.
They were originally cast by M & A for Scott Brayton Engineering (the late Indy driver).
Not sure of how many were originally cast, since I've heard numbers between 9 and 11. They are for the most part an on center SII motor with some interesting differences.
I had two, sold one.
The outer two of the six coolant holes across the top of the deck on this version of the 153. More than likely yours won't have them but worth a look. I will e-mail you a pic.
Originally posted by JoyOf6 The outer two of the six coolant holes across the top of the deck on this version of the 153. More than likely yours won't have them but worth a look. I will e-mail you a pic.
My Stage Heads do not have steam holes on the lower (outer) portion of the head to coinside with the block that does have holes drilled (I WONDER WHY).
Should the block (outer) steam holes be plugged when using the MLS gasket?
To plug: Tap and w/Sq. tapered (soft iron) plug, broke off and surfaced = no more steam hole (s).
Also: add 1 small bottle of BARS stop leak as insurance against leaks...
Also: Why isn't the cam retaining plate (Danny Bee) indexed @ 180 degrees to keep from entering an oil gallery, as would be a 120 degree design?
You guessed it, the assembled short block gets to come apart (again)...
