Brand New Be Cool Radiator/Dual Spal Fan Kit, Moser 28-spline axles, Summit Rear End Cover/Girdle
V6UnderPressure
The Artist FKA Scott4DMny
1. BeCool aluminum radiator brand new never run with mounting brackets for Spal Dual Fans. Part number for the radiator is 60062. It is meant for external coolers so it does not have any trans cooler or oil cooler provisions. It can be found on Summit for $581. I will let the Radiator/brackets go for 450 shipped. All you need is the dual spal fans and this is equivalent to a BeCool cooling module which goes for over $1000! If someone buys this radiator tonight, I will throw in a Casper's Jumper harness for the Spal Fans. So get the Spal fans and that is all you need for a full setup!
2. Moser 28-spline axles with 2.5" ARP studs installed. SOLD!
3. Summit Aluminum Rear End Cover/Girdle. This piece was installed but never run. The gasket can be reused. SOLD!
Now for photos:
I was just informed I forgot to post the photo of the front of the rear end cover. I'll get that up tomorrow.
