Brand New Garrett TE45A $850 shipped
hboost
Banned
This is a Brand New Garrett TE45A with a Precision Turbine Housing. The compressor housing is in polished finish. This turbo is new and never been ran. 3 bolt inlet manifold. Capable of 700-750HP max. 66mm compressor capable of 73ppm, Turbine wheel 76mm Big Shaft P-trim, Compressor housing has a 3 in. inlet, with a 2 in. outlet [60A/R], Turbine housing containing 63A/R Precision and .930 in. wastegate hole, with 5 bolt discharge downpipe all 8mm bolts. This turbo has Dual Journal Bearings with a 360 dynamic thrust bearing.
Thanks,
Joe
hboost@yahoo.com
Where did you get the oil return fitting? how much? What size line 10AN?
Thanks,
Joe
hboost@yahoo.com
Damn... I want that!!! cash in hand!!! :(
