Brand new Racetronix injector hot wire
G NASTY
Brand new, never removed from the bag. 60 shipped.
FEATURES:
Hotwire interface for alternator-direct power
Genuine Delphi connectors
Factory-style appearance
Extended harness length for easier routing
Injector number embossed on both sides of the injector connector
TXL 16 gauge automotive-grade wire
EIA standard color coded wires for easy identification
The Racetronix replacement harness is a step up in quality from the factory piece but also offers the option of supplying alternator direct power to your injectors. While gains can be had with hi-z injectors this harness really starts to shine when used with low-z injectors. The factory wiring system was never meant to support low-z injectors where load resistance can be as low as 0.3 ohms (6 x 2 ohm injectors). Current demands go through the roof as injector duty-cycle increases. The factory wiring system starts to drop major voltage through the positive feed side of the factory harness where all the injectors are wired in parallel. The Racetronix harness works in the same fashion as our fuel pump 'hotwire' harness where the factory supply triggers a heavy-duty weatherproof relay which in turn supplies + power directly from the alternator through a heavy-gauge wire & 30 amp-rated interface connector directly to the load (the factory 7-terminal connector is rated at 14 amps max.). People who run low-z injectors and the Racetronix injector hotwire harness assembly will have improved injector opening time resulting in a number of related benefits:
Reduced cranking pulse-width
Improved transitional / acceleration-enrichment fueling
Reduced injector duty-cycle / pulse-width under all conditions but mostly under higher duty-cycle / W.O.T. conditions.
Improved injector timing stability / consistency at high duty-cycle / W.O.T.
This product was developed to address a few recurring problems with customer's cars. Some customers had bought 14 gauge injector harnesses only to find little or no improvement. Most of the voltage loss is in the + side feed and not in the injector harness itself because at that point each injector has a dedicated + feed. After running some tests we found + side injector voltage under W.O.T. was at or below 8V in many cases. Trying to draw six to ten times the factory load from a stock harness was bad news.
These harnesses will benefit / work in conjunction with Volt Blasters / Volt Boosters.
These harnesses will not interfere with any other items wired to your alternator such as fuel pump hotwire kits etc.
Low-z injector drivers (modified factory ECMs and aftermarket PCMs) will reduce average current demands but full current is used to open the injectors.
Batch-fire and bank-to-bank EFI systems will benefit more at lower DCs than SEFI systems due to the fashion in which they fire the injectors.
