Breaks
  • Thread starter Thread starter ITforMKT
  • Start date Start date
I
ITforMKT
Guest
My breaks pull from to the left when I first apply. Then back to the right. After I hit the breaks a few times the work fine. I have replaced everything from the master cylinder to the rubber break lines on the front, all calipers, wheel cylinders everything except the proportional valve. Any help out there? Thanks
did you replace the rubber lines...I think you meant you did.
Have you checked the ball joints?
Not to sound too obvious, but where they bleed correctly? The powermaster can be a tricky beast!
You didnt mention new calipers. I think theyre only like $15.00 from the parts store.
Thanks to all of your replies to my break problem. I have replaced the calipers, rear drums and the rubber lines.
I am not sure what you mean about the rear drums being lot of adjustment . Can you explain?
Bleeding the master cylinder is a possibility. Do you have a technique that works?
Have the upper control arm bushings been changed? This is a turbo car, right? The passenger side bushings gets cooked and the upper control arm rotates rearward under braking, changing the caster and the car can pull to the left.
