breather with a catch can
blackgn1
Set on TSM Boost
Please excuse the drawing but will this simple setup work? Breathers with connections for rubber lines. Found some breathers in Summit with AN connectors and could also use an AN tee to tie the breathers together then one line to the can which has a breather.
Yes, it'll work. I have a similar system on my car except with two catch cans, one for each side...
Claude. :)
1st, Doesn't have to be blue prints, simple drawing, detail, it's all about getting the Idea out there:cool:
2nd I had this in mind as well ;)
valve cover breathers with a catch can
Just remember to vent your catch can....either into the atmosphere or back into your MAF pipe otherwise it will be sealed and won't work.
I've been thinking of doing a similar dual valve cover breather set up, however will be venting them back into the MAF pipe (similar to factory passenger valve cover venting).
Can you post some pics and part numbers of your AN breathers and fittings from Summit (I'm interested in something similar).
Like to see some pics of your set up when it's done.
Thanks,
dave
I run one catch can off the driver side valve cover. The passenger side I plugged.
There are a couple pics here
Check out Summit Racing part number CAL196500. Looks like my Precision Upper Plenum.:biggrin: I got to do it!:biggrin::biggrin:
