BRF trans, billet and rollerized
brian
Senior Member
BRF 2004R trans, fresh & ready to go.
This is a solid bottom 10 sec capable street/strip trans.
Billet drum and input shaft, fully rollerized gear train, front pump and output shaft, custom servo, and trans brake (stage right type, but quicker, and better releasing). This is a lock up trans.
The unit also has 550 and 400 boost valves, rev kit, Alto wide red band, billet anchor pin, and extra clutches throughout.
shifts are medium at part throttle, firm a WOT. (not harsh)
This trans also has a Hughes deep cast aluminum pan with drain plug.
$2500 outright shipped to you (cont U.S.). Look around and compare prices, this is a great deal with the core included.
1 year no B.S. warranty.
Feedback can be viewed in the feedback area. Search under, brian or Brian Hofer.
Thank you very much...
Brian hipsibri@cs.com
This trans features:
Billet forward drum
Billet input shaft
Billet OD ring gear
Billet anchor pin
Transbrake
deep cast pan
"Case Stretcher" servo
Alto wide band
7 directs
5 forwards > clutch packs
3 clutch OD
Rollerized pump, output shaft, low roller, drum, center support
upgraded TCC switch
new pressure switches
higher pressure spring
rev kit
550 and 400 boosters
hardened stator support
resurfaced pump
all new bushings and bearings
TTT from another satisfied customer! Brians tranny has given me NO problems at all and work perfect Daniel Ray
This is the same build tranny I have, trust me, Brian builds an incredible tranny!
Are you running a 700r filter? If so, did you have to mod the Hughes pan to accept the filter? Sorry for the highjack..:)
It is a 700 filter in it, but Brian will have to say whether or not any modifications were done to the pan to accept it, as I have not done a service to it yet.
Thanks for the props Eric!;)
The Hughes pan can come in either fashion. 200 or 700 filter. The later versions I have gotten from Summit have had a 700 filter.
Sometimes you just have to grind down the pads a touch for the 700 filter to get the pan to seat.
Brian
Trans is sold, pending payment receipt. :)
Thank you all for your support!
Brian
