I went to AZ to find a replacement, no luck. I went to O'Reilly and I found what I thought was a replacement, PN 47150. I'm not sure if it is working correctly. The stock doesn't allow any pressurized air through and the replacement does. I think it is defective. The replacement one doesn't just blow pressurized air directly, it does build some pressure, but it does bleed down to zero. Probably not the way it is supposed too work.
