I think that failure came from knock. I'm betting the knock sensor is unplugged or has a issue in the wiring. In the fast B2B i beleive that if you set the timing attack rate to zero. when knock occurs and it doesn't pull any timing it will show no knock.
Also verfing the timing is a very important thing to do on the aftermarket ecm's. I have found a few gn's that the timing was off as much as 5 degrees.
One other thing you might want to consider is have the Wideband checked.
on a another side note if ya run alky and pump gass run it a tad richer say 10.8 -11.0 any leaner than that is asking for trouble IMO
Yea i guess everythings going to have to be checked on the new motor set up and checked again. I took alky out its for sale in the for sale section
If this failure just happened for know reason it's got me bumed as i just purchased a stroker set-up from mike licht before Xmas.
