Broken timing chain/ electrical problem
darth
Thank you to all of you who told me my timing chain was broke. It turns out that I wasnt aware that you do not use a tensioner when switching to a double roller chain. Lesson learned. I now have a new problem. When I set the cam sensor I can get the lite to turn to set timing but when I try to start the car the lite does not turn on at all. Any ideas? Crank sensor, bad wire, It is not the cci fuse but I feel like an idiot this car confuses me terribly sometime. If anyone has any ideas I would sure appreciate any help.Thanks
.......... I now have a new problem. When I set the cam sensor I can get the lite to turn to set timing but when I try to start the car the lite does not turn on at all. Any ideas? Crank sensor, bad wire, It is not the cci fuse but I feel like an idiot this car confuses me terribly sometime. If anyone has any ideas I would sure appreciate any help.Thanks
Did you look at the link "Crank but no start" in the sticky?
