Bruce AT PTS Help w/one of your Trans
Evaddave 87gn
Always learning...
Bruce,,
I spoke with you about my trans. Invoice #5118 . You said to take line pressures then contact you.
Here are the original numbers from your sheet
P:120,300,285
R:160,255,240
N:120,300,285
OD:125,265,240
D:125,250,240
2:140,250,235
1:135,245,230
I warmed up the car and then took the following readings, leaving the TV attached for the Idle at 1000, then removed it and pulled half way (approx) at 1500, then full at 1500. These are the numbers I got. (doesn't look to good.)
P:120,170,175
R:160,135,135
N:122,164,165
OD:85,140,145
D:80,125,120
2:85,105,105
1:75,95,97
Any input would be great.
Evaddave
No, used
I was told it had approx. 2000 miles on it. Not so sure now. But i'll wait to see what Bruce thinks.
Evaddave
If you get this moved to Transmission Tech, Bruce might see this as he usually does not view other areas.:smile:
Can you tell me how?
I do not know how. Can you help me? Or should i just copy and paste?
Evaddave
I have relisted in Trans
I have re-listed this query in the transmission section. Administrator please delete. Thank you.
Evaddave
