Evaddave 87gn
Always learning...
- Dec 16, 2005
Bruce,,
I spoke with you about my trans. Invoice #5118 . You said to take line pressures then contact you.
Here are the original numbers from your sheet
P:120,300,285
R:160,255,240
N:120,300,285
OD:125,265,240
D:125,250,240
2:140,250,235
1:135,245,230
I warmed up the car and then took the following readings, leaving the TV attached for the Idle at 1000, then removed it and pulled half way (approx) at 1500, then full at 1500. These are the numbers I got. (doesn't look to good.)
P:120,170,175
R:160,135,135
N:122,164,165
OD:85,140,145
D:80,125,120
2:85,105,105
1:75,95,97
Any input would be great.
Evaddave
P:120,300,285
R:160,255,240
N:120,300,285
OD:125,265,240
D:125,250,240
2:140,250,235
1:135,245,230
P:120,170,175
R:160,135,135
N:122,164,165
OD:85,140,145
D:80,125,120
2:85,105,105
1:75,95,97
Evaddave
