May 31, 2002 #1 B buickboy Active Member Joined May 24, 2001 Messages 1,151 Installed this awesome pan and bottom feeder and added 8 quarts so far. Does not even read on the stick. How many quarts does this bad boy hold until the stick reads normal level? Mitch
May 31, 2002 #2 S stangbanger New Member Joined May 28, 2001 Messages 100 With a dry tranny and a new 9/11 converter, mine held 16 Qts. I'd put 15 in, run it on jack stands through the gears, and then check it.
May 31, 2002 #3 S squeeze87 New Member Joined May 27, 2001 Messages 354 bottomless pit When I installed my deep pan, it took 11 quarts to read full! This is on a trans with oil in the converter,cooler.
