SignUp Now!Hello
I had to remove the emblem from the front grille and the retainer clips broke that hold it in place. Where could I order this or is there something else I could use?
Thank You for any help
I would swear that my 'BUICK' emblem on the grill was loose about 20 yrs. ago and I tightened it with 2 screws that were behind it?
I checked it recently and it is molded in?! I can't get it off without cutting it! What gives? Was a switcheroo pulled when I left it at a
vendor's for a couple months?
That's odd, I wonder if someone broke/lost the nuts or broke the stems and they just epoxied it onto the grill. Was the car/grill painted recently at this vendor?
Ah, so it did have nuts on it. Now that you mention it - I did have the car painted last winter, maybe he did screw it up. The Buick emblem is not something I normally look at on the pre-flight check.
I can't go out and look right now as the car is at JW Racing in Seymour, CT getting a little 'work' done to it - then it's off to Otto for a dyno tune. This will remain a mystery for a little while longer....
Thanks for the insight Rubicon 327!
Otto is working full time at the shipyard - he'll tune a car here and there, maybe - I wish he was back, he's awesome!!!
