80turbomonte
- Nov 3, 2004
did the other power valve with the check valve to the intake now it does this runs up to 2000 then dies just like a classic vacuum leak used the carb cleaner to locate leak and nothing. took turbo off(what a pain) put new gaskets in, changed nothing. re-torqued intake bolts. (used felpro). iam totally stumped way to much money in this buick v6 to be doing this. got maybe 5 miles on it(in over a month) thinking ill put my small block back in it try to salvage some money back out of this brand new 4.1 any takers????? holds 50 psi oil pressure hot 40 in gear when it stays running.
