Buick t-type project $4000
turbognx75
1985 Buick t-type with a 1987 drivetrain, lifted with heavy duty coil springs and 22" rims it has a fiberglass hood it has a 3" ATR stainless single shot it has a 3" steel downpipe it has GNX style cluster grey leather seats in great condition carpet is in great condition also needs a shifter handle so I turn steering column to put into gear it has a new gas tank not sure what pump in tank I have an extra set of headers in trunk cause I think drivers side is cracked. It still needs the iac and tps set and the Trans shifts into gears fast if u drive without mashing pedal, normal driving,,,but when u mash the pedal it shifts normal and at the top of gears....I talked to a Trans guy he said could be torque converter solinoid or the valvebody, it pops at about 11psi could be from iac/tps maybe coil haven't really tried to figure it out. I installed new plugs and wires. It has rust by the right rear quarter looks like someone didn't do a good job, I'm sure I'm forgetting some stuff about the T but text me any ????'s u have... I don't have time to mess with this car so ask or come check it out...needs a headliner and Has a moonroof that doesn't work I cant find the switch for the moonroof. It needs stock springs to bring it back to earth and stock rims and some tlc...thanks Tony 6306697676....oh it has an alarm system from hell on this car when u start it u have 20sec to hit two buttons under dash and if u don't it will kill the fuel pump ...I can't remember everything so text or post or pm me questions it has a stock ported turbo stock IC motor was rebuilt not sure what's inside of it. Thou it does have arp head bolts but I'll guess that it's all stock and has an intake too....I'll throw in some cheap steel rims and tires also....car is located in westmont il......
That alarm system is called Blackjax made by Clifford . I install those they are $500-600 installed thats a great deal on that car with that system it cuts off ignition starter and fuel pump if setup that way. GLWS
looks like a lot of car for the money. put it on craigslist with a phone # and pics and you probably will sell it there
I thought so to for $3500 but no luck on CL no one wants a jacked up turbo regal I'm sure if it was stock height it would have sold....
I could use the stock ECM if you do part it. Plus I'm close by.
Interested in the gnx cluster pending pictures. Pm me pictures and price to 33317.
I saw this car in person, I actually bought the black Regal you had for sale. I would of bought this car too if it hadn't been for the big springs and big wheels
Anybody want to offer anything for this roller before it goes on eBay....still has some good stuff. Carpet, seatbelts, fiberglass hood, rad, 8.5 dif non posi, clean frame with clean title, moon roof, dashboard no cluster, top speaker cover not broke or bent, vacuum brakes, a/c box, wiper /motor, etc
