On another note I set the cam sync reference at 30 BTDC based from the TDC mark on the balancer, which I confirmed is correct, when I degreed the cam using the piston stop. The fast is showing the cam sync between 95-100 degrees, why would 30=90-100? I thought when we used the Dis module it processed the numbers different, but now its eliminated out of the system. If we go to the factory setting 25 ATDC for the cam sync using the module , the fast will still show 85-95 degrees cam sync also..odd
