Also, a word of note, if you added fuel to a cyl based on a 15 lbs pass and then did a 30 lb pass your settings would probably be wrong. Also the Injector offset is the same way its only good for a certain rpm. So both of these nice features, need to be improved upon based on more than one variable to be really effective, maybe newer software will have this.
IMO: The injector offset isn't a big deal. Once you start increasing the rpm and the overall p/w increases, the offset becomes such a small part of the overall fuel calculation and the fact that it is somewhat linear, it will easily be compensated in the VE table.
I would agree that the individual cylinder correction can be off slightly at different boost levels. But only if the boost is quite different. Lately, I have been testing several cars with WBO2 in each cylinder and it's been an eye opening experience. Based on your example, If I had a car running 15psi it is probably a pump gas/street tune where as the 30 psi would be a race tune. I would just set up the individual cylinder correction differently in each tune.
With all this being said, after testing individual cylinder WBO2, earlier this year, I spoke to "the powers that be" at FAST about revamping the individual cylinder correction tables perhaps more like the BS3 does. The reality is, 90% of XFI customers don't even use individual cylinder correction. Of those that do, 90% of those wouldn't have the means to isolate the correction based on load or rpm.
