4L80E BUILT, ROSSLER ROSS-LOCK PRO TREE TRANS BRAKE, MODIFIED DRUM WITH QUICK RELEASE SPRINGS, B&M DEEP PAN, ART CARR TAILSHAFT CABLE SPEEDOMETER ADAPTER FOR BUICK GN, PRO TORQUE 3500 L/U CONVERTER,ReprogramED Valve body FOR Ross-Lock ,ModifIfied Pump TCC Apply System, 36 ELEMENT SPRAG,KEVLER BANDS, EXTRA CLUTCHES, ALL NEW SEALS,NEW SELENOIDS,MODIFIED CROSSMEMBER INCLUDED, MODIFIED DIPSTICK, MODIFIED CASE TO FIT IN TRANS TUNNEL WITH NO HAMMER.
4l80e Pro-Tree trans brake
THIS UNIT WAS SPECIFICALLY MODIFIED FOR A BUICK GRAND NATIONAL
JUST GOT TRANSMISSION REDONE AND TWEAKED......DROVE IT FOR A FEW MILES WENT TO THE TRACK AND CRACKED A CHAMPION HEAD. MY LUCK, SO NOW IM CHANGING MY COMBO
THIS TRANSMISSION CAN BE SMOOTH AT THE BOTTOM BUT NECK SNAPPING AT WOT.
IT WOULD COST MORE THEN $5000 TO REPLICATE THIS 4L80E
ASKING $3200
ALL YOU WOULD NEED IS A CONTROLLER WHICH IS ABOUT $1000
I DO HAVE A BRAND NEW GMPP ONE WITH THE WIRING HARNESS FOR A 4L80E
FOR $750
OR YOU CAN GET " THE LITTLE BLACK BOX" FROM ROSSLER, FOR MANUAL SHIFTING ,WHICH IS $295
ANY QUESTIONS YOU CAN REACH ME AT
310-923-4377 LUIS
ASKING $3200
FOR $750
310-923-4377 LUIS
