Bumper Filler removal (Front)
BlueLimited87
To remove just one side (pass.) of the front bumper filler, does the complete bumper have to come off the car.
I was told you can remove it by just taking out the headlight (bezel) assembly out and un-bolting.
Yes you can do it with the bumper on. You dont need to remove the bezel. All of the bolts/screws are from underneath. If I'm not mistaken there a 4 10mm headed bolts holding it to the fender and 4 7mm screws and one plastic clip holding it to the header panel.
(3) 7mm there is also 3 tabs that lock into the header panel.
