Dynagear double roller timing chain set new (was on engine, but never run. this is the style that requires shims because the crank gear is about .030" thin) $15
Power trunk latch with solenoid $25
Chrome up pipe (driver quality chrome, has hole for alky nozzle) $25
3" catalytic convertor assembly for Mease down pipe. Barely used (only used to go through NJ state inspect so its still pretty much like new) comes with a band clamp. Should fit Terry Huston, ATR and other down pipes as well. $150
Set of Pioneer speakers (6x9 and 3.5") $25
Turbo 400 and turbo 350 mechanical modulator (for installing an automatic shifting trans with your turbocharged engine. Brand new with instructions. $100
Perfect pair of stock main caps from a 109 block. These are the 2 center mains. $25/pair
Mass air bracket and pcv vent cap from a Kenne Bell cold air kit $5
Ported stock down pipe elbo $40
Stock unported down pipe elbos $20@
Stock NA crank. Good condition $75
Stock inter cooler fans $30@
All items are plus shipping. Dont like the price? Make me a reasonable offer.
I will be posting more stuff soon. Just have to dig the stuff out!
