bunch of parts
projectmoneypit
tx firefighter
Still cleaning up after my build, lots of parts still need to be inventoried. Parts are plus shipping. Thanks. Greg
GRAND NATIONAL REGAL PARTS
INTERIOR
#5 HVAC VENT BOX MOUNTS TO BULKHEAD BEHIND DASH $20 O/H 2 SHOP ATTIC
#7 LEFT REAR LOWER SAIL PANEL GREY/BLACK $15 SHOP ATTIC
#8 LEFT UPPER REAR SAIL PANEL GREY/BLACK $10 SHOP ATTIC
#9 RIGHT UPPER REAR SAIL PANEL GREY/BLACK $10 SHOP ATTIC
#10 RIGHT LOWER REAR SAIL PANEL GRE/BLACK $15 SHOP ATTIC
#13 REAR METAL HEADLINER TRIM $10 O/H 2 SHOP ATTIC
#26 POWERMASTER BRAKE PEDAL ASSY $30 O/H 2 BOX 1
#29 DASH HARNESS RADIO PLUG CUT 1 SPLICE $150 BOX 1
#37 LOWER DOOR PANEL SEALS $10 PR BOX 1
#47 PASSENGER UNDER DASH COVER $10 O/H 3 BOX 1/2
#48 SEAT BELT TENSIONERS 2 PAIR O/H $10 EA BOX 2
#49 DOOR JAM VENT $10 BOX 2
#50 DRIVERS SEATBELT GUIDE GREY $10 BOX 2
#51 REAR TTOP HEADLINER TRIM GREY 2pcs $30 BOX 2
#53 PASSENGER KICK PANEL 3 PIECES GREY 2 O/H $30 BOX 2/TRUNK
#54 DASH CLUSTER DASH PAD GREY $30 BOX 2
#55 VACUUM BRAKE PEDAL ASSY $30 BOX 4
#56 RADIO BEZEL NICE NO BROKEN TABS 2 O/H $15 BOX 2
#58 PASSENGER LOWER PIVOT SIDE SEAT TRIM GREY $10 BOX 2
#59 TTYPE HORN PAD WITH HORN PLATE BURGANDY $10 BOX 2
#61 INSTRUMENT CLUSTER MOUNTING BRACKET $50 BOX 3
#62 ACCELERATOR PEDAL WITH HARDWARE $20 BOX 3
#63 REAR VIEW MIRROR $5 BOX 2
#68 BURGANDY SUN VISORS NO MIRRORS, REDONE $50 PR BOX 3
#69 BURGANDY REAR STEERING WHEEL COVER $10 BOX 3
#70 GLOVE BOX INSERT $10 BOX 3
#71 HVAC CONTROL HEAD COMPLETE MANUAL $40 BOX 3
#72 HVAC CONTROL HEAD COMPLETE MANUAL $40 BOX 3
#74 LARGE GREY TTOP CENTER TRIM NEEDS PAINT $25 BOX 3
#75 PASSENGER B PILLAR GREY FOR TTOP $15 BOX 3
#89 HVAC BLEND DOOR CABLE $10 BOX 2
#90 GLOVE BOX LATCH/LIGHT SWITCH $5 BOX 2
#94 GN DASH PLAQUE (1) $75 EA BOX 1
#96 ARM RESTS DOOR PANEL GREY PAIR 2 O/H $30PR BOX 3
#97 NOS DOME LIGHT LENSE ROUND (2) $10EA BOX 3
#98 HORN CAP AND RING TURBO 6 NICE SHAPE GREY $75 BOX 3
#103 DASH PANEL GREY BARE $150 ATTIC
#107 INSTRUMENT CLUSTER ANALOG (FOR PARTS) $15 BOX 3
#113 DOOR SILL PLATES 6 O/H $12EA ATTIC
#124 KICK PANEL DRIVERS GREY $15 TRUNK
#126 REAR SPEAKER HANGERS $10PR TRUNK
#127 REAR SPEAKER PACKAGE TRAY BOARD GREY $25 TRUNK
#129 COVER REAR STEERING WHEEL GREY $10 TRUNK
#133 UNDER DASH VENT GREY DRIVERS SIDE $25 BOX 5 PIC
#135 GREY LOWER SAIL PANELS $50 PAIR UHAUL PIC
ENGINE COMPARTMENT
PART DESCRIPTION PRICE PART LOCATION
#2 84-87 RADIATOR CORE SUPPORT $75 SHOP ATTIC
#11 MAIN HVAC HOUSING ASSY FOR BULKHEAD $75 SHOP ATTIC
#25 HVAC BOX ENGINE COMPARTMENT SCREEN $30 BOX 3
#30 INNERCOOLER FAN $15 BOX 1
#31 A/C CONDENSOR $20 SHOP ATTIC
#32 HEADER PANEL TOP BRACE $15 O/H 2 BOX 1
#33 TRANSMISSION INSPECTIO0N COVER $15 BOX 4
#34 BLOWER MOTOR WHEEL $5 O/H 3 BOX 1
#35 ENGINE OIL COOLER ADAPTER AND HOSES $40 BOX 1
#36 HOOD HINGES O/H 2 PR $15 PR BOX 1
#38 84-85 HOOD TURBO HEAT SHIELD $10 O/H 2 BOX 1
#39 A/C DRYER $10 BOX 1
#41 WIPER ARM LINKAGE $20 BOX 4
#45 POWERMASTER COMPLETE INOP MOTOR CLICKS $80 BOX 4
#60 ACCELERATOR CABLE $20 BOX 2
#64 COOLANT OVERFLOW BOTTLE WITH CAP $15 BOX 2
#65 CRUISE CONTROL CABLE $10 BOX 2
#66 CRUISE CABLE SERVO BRACKET $10 BOX 2
#67 HOOD RELEASE CABLE $10 BOX 2
#82 UPPER SPEEDO CABLE $10 BOX 2
#85 HOTAIR TURBO HVAC BOX HEAT SHIELD $20 BOX 4
#86 WASHER BOTTLE WITH CAP 2 O/H $10 BOX 2
#88 DRIVERS INNER FENDER WELL TIRE RUB HOLE $25 SHOP ATTIC
#91 FRONT RAD SUPPORT CROSS BRACE 2PCS $10 BOX 4
#106 TURBO J BRACKET $50 BOX 4
#108 WIPER ARMS BLACK PAIR $30 BOX 3
#111 SEAL COWL HOOD $15 BOX 3
#115 SPEEDO CABLE UPPER $20 BOX 3
#119 COOLANT OVERFLOW BOTTLE 84-85 W/CAP $15 BOX 3
#121 FLEXPLATE $25 BOX4
#123 86-87 A/C LINES $100 TRUNk
BODY
#3/4 REAR WINDOW W/WO/DEF (0) WITH DEF (2) W/O $40 SHOP ATTIC
#6 REAR WINDOW OUTER TRIM 3 PC $30 SHOP ATTIC
#12 DRIVER DOOR WINDOW (3) EA $50 SHOP ATTIC
#14 WINDSHIELD TRIM 3 PC $50 SHOP ATTIC
#15 HOOD TRIM NO DINGS NEEDS PAINT $25 SHOP ATTIC
#16 RF WHEEL WELL TRIM NEEDS PAINT BLACK $40 SHOP ATTIC
#17 RR " " $40 SHOP ATTIC
#18 LF " " DENT DING PAINT $10 SHOP ATTIC
#20 LR " " $10 SHOP ATTIC
#21 RR " " $10 SHOP ATTIC
#40 TRUNK LATCH NON ELECTRIC $7 BOX 1
#42 GAS TANK STRAPS 2 O/H $25 BOX 4/TRUNK
#43 PASS QUARTER WINDOW CHROME TRIM NICE $20 BOX 1
#46 TAILLIGHT FILLER NO LICS PLATE LIGHT $15 BOX 1
#78 PAIR QUARTER EXT NO SPOILER HOLES $30 BOX 2
#79 PASSENGER WINDOW $50 ATTIC
#92 WINDSHIELD TRIM BLACK VERY NICE $50 ATTIC
#95 DRIVERS SIDE HEADLIGHT MARKER 2 O/H $25 BOX 1
#99 87 GRILLE BLACK CLEAN BREAK COMPLETE $125 ATTIC
#101 REAR LISCENSE PLATE FILLER W/LIGHT $20 BOX 3
#104 MIRROR DRIVER REMOTE 3 O/H $30 BOX 3
#110 MIRROR PASSENGER REMOTE 1 O/H $30 BOX 3
#112 LOWER WINDSHIEL TRIM BLACK 2 O/H $20 ATTIC
#114 REVERSE LIGHT LENS DRIVERS SIDE $15 BOX 3
#116 DOOR PASSENGER NO ROT RUST SOME DENTS $50 SHOP
#132 PARKING BRAKE CABLES 3 PCS GOOD SHAPE $60 TRUNK
#136 REAR QUARTER EXTENSIONS WITH SPOILER HOLES $30 BOX 5
WIRING
# 76 CRUISE CONTROL HARNESS/ VAC HOSE 2 O/H $25 BOX 2
#77 TAILLIGHT HARNESS FROM DASH TO TRUNK $30 BOX 2
#80 TAILLIGHT FUEL PUMP HARNESS F/P WIRES CUT $30 BOX 2
#81 REAR WINDOW DEFROST WIRING HARNESS $10 BOX 2
#83 PASS DOOR WIRING HARNESS PW PL 2 O/H $25 BOX 2
#84 DRIVER " " 2 O/H $30 BOX 2
#109 POWER ANTENNA HARNESS W/O CABLE $10 BOX3
#122 ECM 84-85 2 O/H $50 BOX3
MISC
#24 51.5 INCH 200R4 GN DRIVESHAFT $75 SHOP ATTIC
#28 USED STOCK REAR COIL SPRINGS 3 PR O/H $25 PR BOX 1/4
#100 TRANS LINES CUT @ RAD $25 ATTIC
Need clarification, is the Driver side Marker light? #95 DRIVERS SIDE HEADLIGHT MARKER 2 O/H $25 BOX 1
How much shipped to 75094?
yes it is the drivers side marker that attaches to the headlight bezel, driver condition. shipping in a priority flat rate envelope is $6.75 with tracking # and paypal fees. I will also check the weight of it boxed as it might be light enough to go first class mail if it weighs less than 13 oz. you are about an hour north of me, i am about 20-30 min s of dallas in Waxahachie. So if you need more parts it might be cheaper for you to come on down.
It is less than the 13oz, if you want to stil ship just pay the above price and i will refund the difference once i find out how much shipping is.
Is pass side remote still available? do u also have the dash plastic insert? is it fully operational? does it need a repaint ?
Johnathan
Johnathan
pass remote mirror, yes i have a few. What plastic insert are you talking about? Mirror works good, already gn black and is in good enough shape for daily driver.
Could you send me some pics of the stock intercooler (#1)? If it's free of damage, I'll take it. Thanks.
sold 2 innercoolers today, only 1 left. It is 20 plus shipping because it is off that flood car so it is corroded on the inside and some fin damage. If you are still interested i need your email for pic
