Hydroboost Braking
The Hydroboost Will Set That Line Lock Hard With Higher Pressure. It Locks The Fronts Only. The Hydroboost Without A Line Lock Will Hold The Car, But Also Holds The Rear Brakes On During A Burnout. The Only Time A Hydroboost Will Not Hold In A Drag Race Start, Is When The Stock Crank Pulley Overspeeds The P/s Pump. At About 6000 Crank Speed, The P/s Pump Is Turning 10,000rpm. This Is So Fast, That The Vanes Can't Pull In Fluid To Pump Pressure, And The H/b Backs Off With Low Pressure. For Drag Racing, The Crank Pulley Needs To Be Smaller In Diameter, To Slow Accessory Speed Down. At 6000rpm, The Alternator Is Over 24,000 Rpm! Water Pump Speed At 10,000 Rpm! Horsepower Wasted!
