burnt tranny fluid, should i change it?
rwrows
i think i burned my tranny fluid a little while beating on the car tonight. do you guys think i should change the tranny fluid or let it go. the trans is fresh with a 9/11 converter. thanks.
Change the fluid, and inspect the bottom of the pan for excessive sediment. I assume you have a massive tranny cooler for your fresh transmission with the 911 convertor.... Heat kills transmissions.
Billy
Billy
yeah the tranny cooler is pretty massive. i was repeadedly flooring it because i was trying to figure out why i was getting knock and trying to adjust my alky settings and watching the boost guage
