hemi8
Goin Sideways
- Jun 6, 2001
I've done a few searches and can't find much info. Did you build your engine with a CAT crank? If so, what clearences did you see on the rods and mains? Does any work need to be done to the crank or is it ready to go from CAT? This crank is internally balanced, does this cause us trouble or is this no big deal for the machine shop? If we use a different SFI balancer, how do we get the signal to the crank sensor, do these balancers come with a factory interupter ring?
Mike
86 GN
Awaiting the release of Champion's Stage 2 block.
Mike
86 GN
